I am currently redoing my bathroom and want to install downlighters and am also considering an extractor fan.
I like the idea of being able to dim the downlighters and have seen that you can by a bathroom pull cord with dimmer ability built in (from Screwfix / Toolstation). The highest rated one supplies a maximum of 250 watts. I presume you can probably get ones that go higher.
I am also thinking that an extractor fan would be ideal as even though the bathroom has windows I would like to be able to extract the moisture (and smells) without opening a window. I would prefer though to have the extractor operating independantly to the lights.
My thinking was to have a dimmer pull cord in the bathroom to operate the downlighters and a seperate switch on the outside of the bathroom to operate the fan.
I have a number of questions that I would appreciate some advice on:
1). Is it best to buy low voltage (12volt) downlighters as opposed to mains downlighters for a bathroom? (My intention is to have them on an RCD anyway). If so any recommendations?
2). If I bought the dimmer pull cord it is only rated for 250 watts maximum. I was hoping to install 6 downlighters at 50 watts each but wouldn't be able to with this dimmer. Is that overkill for a 2.5m by 1.6m bathroom or should I buy 6 and putt lower wattage lamps in them?
3). What is the best way to wire up multiple downlights to a pull cord? I have looked through the stickys at the top but couldn't see one specifically geared towards downlighters. Though I probably being blind.
4). Some extractor fans come with a light. Are these wired to operate independantly or do you have to have fan and light on together?
I'd appreciate any recommendations and advice.
Thanks in advance,
Daz
PS. I understand that I cannot do the majority of this work as it needs to be done by a professional, but I want to understand my options and have the knowledge behind it all.
Thanks in advance,
Daz
