Looking for advice on a light circuit.
I am aware that each light circuit on a 6amp MCB shouldn't draw more than 1200 Watts (info from a DIY manual). With 6 rooms upstairs this shouldn't be a problem with 6x 60 or 100 watt bulbs....
however i am now installing Down lights with a max wattage of 50, and there will be a total of 25x 50 Watt lights (max of 7x50 watts in one room/ one dimmer the other rooms average 4x50) + 100 watts in the loft...
As the combined Watts on the up stairs circuit will now be 1,350 Watts do i need to either:
1. split the circuit, therefore have an extra 6 MCB, and have 675 watts on each?
2. Increase the MCB...and if so what size 10 or 32 amp?...and how is this calculated?
3. replace the standard 1.5mm lighting cable with 2.5mm?
