It may be worth having a good look first to see if the gas is already earthed somewhere. Gas fitters and the like assume if the earth clamp is not in the meter box then it's not earthed.
I've already suggested that. As I said, so long as it is 'accessible' I don't see that this is apprecaibly 'worse' that the screw terminal joint which inevitably exists at the MET.Do you think one could even join the earth cable with an earth block (like the MET you sometimes have)?
guidance note eight (earthing and bonding)
Yes, I know. I assumed that EFLI's (enlarged and emboldened) point was that G= 'Guidance' (not regulation). However, although I know what it is, I haven't seen or read GN8, so are you going to share with us what it says about this issue?guidance note eight (earthing and bonding)
regulations are another issue, where are these so called regulation coming from?Yes, I know. I assumed that EFLI's (enlarged and emboldened) point was that G= 'Guidance' (not regulation)guidance note eight (earthing and bonding)
In terms of continuity of the bonding path, it's difficult to how how they could regard it as necessary for 'good practice'. Main bonding exists only to minimise any pd bewteen CPCs (hence exposed-conductive-parts) of the installation and pipework etc. which is in continuity with extraneous-conductive-parts (usually the incoming gas/water pipes). In most situations, there will be at least 6 (often more) screw-terminal joints in the bonding/CPC path between the incoming extraneous-conductive-part and any exposed-conductive-part. To suggest that one additional screw terminal joint in the path to one of the incoming services would turn the situation into 'bad practice' would be a bit hard to justify!It seems that this is not even considered necessary for good practice, given that the IET decided to remove it from even the OSG.
