S
SaladFingers
That doesn't make much sense. We're talking about the eddy current induced in a surrounding conductor (e.g. a metal enclosure) as a result of current passing through the wire. I'm not sure what, if anything, would be meant by an eddy current induced in the current-carrying-conductor (wire) itself!It's because of the magnetic feild. The current is passing through the conductor, not the enclosure, so you'll get an eddy current in the conductor as that's what's carrying it.
Yes, I know, and that's what I said, regardless of the material, the conductor is carrying it, but my emphasis is regardless of ferrites, the enclosure isn't, we don't want a reaction with ferrite material.
I'm afraid that none of that makes much sense to me. Eddy currents will be produced in any conductor (regardless of material) surrounding a conductor carrying an AC current, and the passage of that current through the material will result in the generation of heat. "Reaction of a magnetic field with a ferromagnetic enclosure" (whatever that means) will not, in itself, result in any heat generation if heat is generated, taht would be the result of eddy currents flowing in the material.
Kind Regards, John
Yes, I've just said that.
It's the currents in the conductor which reacts with the magnetic material, hence the reason for a gland plate which is non ferrous, or cutting a slot to cut the magnetic field so that eddy currents aren't induced into the enclosure, which causes the heat. I might have a photo somewhere of some heat damage from such.
