Electric shower
  • Thread starter Thread starter oompah
  • Start date Start date
you can't do that in a forum like this unless you know that the OP will take it as a joke...
i read it and thought you were being serious, and I know what I'm doing..
the kind of people that come here and ask questions like this are better off getting a sparky in..
you've heard the expression "loose lips sink ships"?
well the motto for this forum should be..
"jokes cost lives..."
this is the entire reason that Part P was bought in.. it was supposed to do for electrics what the Corgi thing did for Gas..
you and I can't even touch a gas line.. even though i can braze and solder copper pipes for air con units at work.. and they operate at much higher pressures..
If an air con goes wrong, theres only a very limited amount of refrigerant to burn off (if it is flammable). :wink: Not like a gas cylinder full or the whole national gas grid :lol:
I wasn't getting at that..
what i meant is that even though i know how to solder and braize, I have little or no idea of gas installation or it's regulations..
your average DIY monkey knows how to change a plug, but has no idea of the electrical regs, load calculations and so on..
Point taken
If I see anymore posts that need answering I shall reply with
"Leave it well alone you monkey"
lazygit said:
Point taken
The cu is in the hall way directly under the bathroom so if you get a flood water runs into the unit so why not put one in a cloakroom.
oompah said:
lazygit said:
Point taken
Cloakroom or a location containing a bathtub or shower basin?
You wouldn't really want to install a CU where it can be operated by someone who has a lower body resistance caused by them being wet and naked would you?
