My introduction to gas, was 1980 on a 42" pipe line, I have since then worked a lot with commensal gas, the last was a combined power power station, but I would not do domestic gas, that is a different world.
I know my dad also worked with gas, and he lost some colleagues due to gas, and as a result I have always had a lot of respect for it, OK today we no longer have coking ovens, lighting up the sky when they are pushed, and we don't have tar in the gas which could seal up small leaks, making them hard to find.
But what has all that got to do with electrical credentials? I have only been qualified to work with low voltage, my son has trained with high voltage, but although I have assisted I was not trained, however I have done enough to know it is a whole different world, and rather unforgiving.
OK technically I suppose the PAT tester wand at 2.5 kV is high voltage, as was a cars ignition circuit, but I am not counting that.
The 600 volt supplied to the TBM motors was the highest voltage I have worked with, in real terms, even if the TBM supplied with 10 kV, so I have only worked with low voltage.
I would not attempt to work with mineral insulated cable, yes trained how to, but that was some 50 years ago at collage, and I accept better option is to get someone use to working with it, so would not attempt to re-wire the local church.
PLC and Drives were my bread and butter, but they have moved on so much, even them today I would be wary of. And when I look back, I realise some of the things I did when young were not really best practice, like refilling worn dash pots with 40 grade oil, it worked, but really the fire risk was unacceptable, proper transformer oil does not burn.
I think last dash pot I have worked with was around 1985, are there still any around?
Around 1995 I was working on resistor and auto transformer starters, would not think many of them left either?
Even the fluorescent lamp, seems to have now gone.
The most complex system found with domestic was central heating, and today most of that is built into the boiler, so all the electrician does is to provide power to the boiler.
As to setting up smart devices, does the electrician really even do that, or is it left to the home owner?
When I started, it was up to the electrician to decide what was safe, and not sure we did that very well, thinking back to the knife switches I saw in Queensferry bridge, open live parts have been banned for many years.
But today we have regulations for near every aspect, although even then, I find myself scratching my head, wondering what is going on.
For example, we were told that the distribution unit used where ordinary people were in control had to be type tested, and it is called a consumer unit. These were made up to 125 amp limit, in real terms 100 amp seemed to be the normal, I hunted the BS 7671 of the time, and could not find where it said this, but it could have been a HSE directive, which would explain why I could not find it. Or even a LABC thing? However today we are seeing three phase being taken to homes, and you can't get three phase consumer units.
Clearly something has changed, I am now retired, so it does not worry me, but it is clear, things are changing. I was told last week I would not find three phase in the home, I named two three phase devices without really thinking about it, my washing machine and freezer are both three phase. OK single phase supply, and an inverter generates 3 phase, but we still have it in our home.
So much has changed, the old red to red, yellow to yellow, and blue to bits does not work with new colours. As to SPD etc, do we really need them? I note my son has loss of PEN detection in his meter cupboard, which will turn off whole house, is that the next thing for all?
