Fitting a blank plate
22 Feb 2015
Yorkshire
Hello,
I am a new home owner and need some advice on fitting a blank plate.
This was the switch for an electric shower which since has been removed so I would like to remove it and fit a blank plate in its place.
I would need to remove the switch, after shutting off the power obviously, and then do what?
Do I wire into a junction box, and in what order?
Any helpful suggestions are welcome :)
Hi,what size of shower was it (kw) the switch seems to have been bye-passed ?
More detail and then we can advise best action to take.
Regards,
DS
I honestly don't know, it's long gone now, ripped out 4 months ago roughly. Is there any other way I can find out?
I suspect it's a switch fuse spur on a ring for a pumped shower, and the plumber removed the flex from spur when removing the shower - DS.
If you check at your CU (fusebox) you should have a circuit marked shower ? You must make sure the supply to the switch is switched off before you do anything. It's the wiring leaving the switch i would want to disconect do you know if that has been made safe ?
Regards,
DS
Switched live?
Sure, if it's for a fan, it might well be - but what I'm not sure of is where (if anywhere) the yellow goes at the switch - it appears to take a pretty circuitous route and then ends up near an earth terminal!
Kind Regards, John
It may well be for a fan, there was an extractor fan that was ripped out also! Apologies for the confusion, I'm not very savvy on this!
Doesn't matter..
Join the two reds together in a terminal block and the blue and black in another, then the earth wires together (yellow/green)
Then fit the blanking plate.
You will need to find out what the other yellow wire does, I suspect nothing, if so, put this in its own block too.
Isolate circuit a consumer unit/fuse board. Test circuit at switch/isolator plate is dead and no other required equipment has been powered down.
If not then you can disconnect the circuit at the unit/board. Terminate cables safely, in case of accidental power up, and blank off.
It looks very much like a ex-fan set-up.
I would disconnect the three core cable and earth and terminate all cores together.
And terminate supply live, neutral and earth individually
Switched live?
Kind Regards, John
I think yellow of 3&e is at load live, the other yellow is for neon indicator.
