simonpearce said:yeah - that wouldn't work. I can't explain why though!!!
On a normal TV signal, all frequencies (474-858 MHz) are received by your antenna, sent down your wire (unamplified) and then the filters in the front-end of the TV select your correct channel (BBC1, BBC2, etc.)
With satellite, the signal is much too high in frequency (14-14.5 GHz) to pump round your house on a wire, so it is converted down to something much more cable-friendly, amplified and then sent down the wire by the LNB. To make the electronics cheaper, it uses a control signal from your decoder to select just the narrow band of frequencies that your required channel occupies, rather than sending all channels down the wire (broadband microwave amplifiers are expensive, or at least expensive in terms of free stuff that Sky gives you when you sign up).
So each channel needs its own LNB. Though the frequencies are very different, think of each LNB as being like a separate Freeview box - different one required for every channel you want to watch.....
