That's passed me by, when did that change?No.
It does.
It's all you'll get if a meter fitter adds it.
It does.
The DNO's property has to conform to a selection of regulations, that's legally conform, in fact they are legally obliged to conform with aspects of BS7671 regs (although not in every respect) whereas what happens after their property there is no legal obligation to conform. An isolator switch is not a CU (nor is it a CU if a distribution board has no main switch), the non flammable regulation you so accurately refer to, IE:Whenever the regulation requiring non-flammable CUs came in.
If it's the DNOs property they are not bound by the wiring regs, AIUI.
Does not in any way refer to any other product than a consumer unit. and an isolator switch on it's own can not in anyway be considered to be a consumer unit.Whenever the regulation requiring non-flammable CUs came in...
Thank youAn isolator in an enclosure is not a consumer unit, distribution board or switchgear assembly as defined in BS EN 61439-3, as there are no protective devices in it, and a single device cannot be used for the distribution of electrical energy.
Thank you
421.1.201 states so.1) How do we know that BS7671 is using the definitions in BS EN 61439-3 when it talks about "similar switchgear assemblies"?
I'm a bit lost here.421.1.201 states so.
Within domestic (household) premises, consumer units and similar switchgear assemblies shall comply with BS EN 61439-3
I will not be arguing about the rest. You can interpret, twist and contrive whatever meanings you want.
I thought that, from the very beginning of this crazy 'non-combustible' nonsense, virtually everyone had accepted that "... and similar switchgear assemblies ..." included things like stand-alone isolators and protective devices etc. which were in their own enclosures
