Fitting scolmore click modular faceplates to plastic backbox
20 Oct 2010
Lanarkshire
Hi just wondering if anyone had fitted the scolmore click grid pro definity faceplates with yoke to a standard plasterboard backbox ?
not the pro definity but i have used the ordinary scolmore click range with no problems. i like them as they have a scew fixing to the faceplate so are not reliant on a plastic clip. unless you are using lots of switches you can mount four on a faceplate without a yoke
Thanks maximum for me is two, I have their 3 way retractive switches and wondered about fitting the screw less faceplates onto cupric back boxes
looking at the click 4 electrics site and if you only want two switches you should nt need a yoke but you might have to create a small lip in the plasterboard for the box to sit in to enable the flat plate to sit "flat"
there are plasterboard boxes with very small mounting "ears" but I imagine they require a very neatly cut hole so the box doesnt fall in. they were mentioned on here a few days ago
edit found the link https://www.tlc-direct.co.uk/Products/MTFDLB2.html
