Fixing to plasterboard
18 Aug 2009
Berkshire
Can anyone tell me the best fixings to use for fitting medium to heavy items to plasterboard walls? Despite the claims of the manufacturers most I have trried are next to useless. They either leave a ruddy great, impossible to use hole in the plasterboard or just end up rotating round in the hole as you tighten the screw
Any help would be much appreciated.
Steve
If you're fixing large items (kitchen cabinets) to walls, best bet is to replace the plasterboard with plywood. No plugs required, screw into it. :wink:
We use these for fixing data cabinets to walls, no problems :)
Found the 'Molly' fixings by Black & Decker to be pretty good fixings ..... expensive though and only found them in Homebase. The one's you just hammer in I like.
If you're trying to fix anything overly large onto plasterboard then you would be better off doing as suggested and using plywood behind plasterboard, or wooden battens if you only need a few fixings. The plasterboard itself is only nailed/screwed to the wall in a handful of places (assuming stud wall), and for that reason, even with good fixings, I would be hesitant about trying to hang anything heavy off it.
