I recently became a landlord and rented out my flat which I have lived in for the last 11 years. As part of the process I had to have a gas safety check carried out. Everything checked out fine except for the flexible hose from the bayonet fitting at the end of the rigid pipework to the termination on the gas hob. The engineer said this should be rigid all the way?
Is this correct? If so, why? Why do DIY stores still sell the flexible hoses if they are not to be used? How come it needs to be changed now when it has been fine for the last 11 years and has probably been fine since the property was built in the 70's?
Any advice would be much appreciated.
