Galaxy flex adding additional keyprox and speaker
25 May 2020
Hi. Would like to add an additional keyprox and internal speaker. Am I ok to run the cables back to the panel like for like as the other pad just ensuring each pad and a different address on the rotary switch. As for the internal speaker it seems unclear where I wire that? Is it wired with the external sounder? The speaker as no tamper just a 16 ohm speaker. Any advice would be much appreciated. Many thanks lee.
25 May 2020
Just a update. Have added the other key/prox and that went well no issues so really just the speaker I’d like advice on. I only want it to sound with the external bell, so just alarm in effect because you can’t tell the alarms going off in the house. Thanks again
7 Jan 2014
Fife
The speaker is wired with one wire to +12v and the other to OP3. If you only want it with the external bell, program op3 to horn. Otherwise, it will give exit tones.
25 May 2020
Thanks so much for your reply. I think I was premature in saying everything went ok with the addition pad I keep on getting once a day atleast burglary 1018 + intruder. Is this because I needed to add end of line resisters to each pad? Or is this unrelated cause do have a few pir taken down as doing other work in the house. Thanks again.
7 Jan 2014
Fife
The zone activation will be unrelated to your keypad. Check that you haven't caused any issues with the power wiring going to the 1018 sensor.
