How much! Bloody pyro would have been cheaper
How much! Bloody pyro would have been cheaper![]()
how frickin thick do you think plasterboard is?
But the cables dont sit at the back of the adhesive. The dry lining guy will put his dots either side of the cable, and as the board is pressed back, the cables are more often than not just a few mm away from the back of the board.
Fix 20mm steel conduit, galv boxes and battens to the wall.
Nail the plasterboard to the battens.
The zones don't affect needing an RCD.Fix 20mm steel conduit, galv boxes and battens to the wall.
although if he is using galv boxes with a blank or accessory, he is in the zones.
