Gas/corgi problem
30 Jan 2009
Yorkshire
About 2 years ago we had a gas cooker fitted, the plumber did all the relevant tests and everything was fine...
This week we had a new fireplace and gas fire fitted by a 'Corgi' registered fitter.
Tonight (Fri) a gas man came to change the meter, when he did a drop test on it before changing the meter he found a leak. He changed the meter and then drop tested it again and it still leaks so he has had to blank it off until we can get it fixed...
Apparently when the fire fitter left he should have done a drop test on the system but he didn't go near the meter (which is locked in the cellar)...
Should we have got a cetificate for this installation and should he have done a drop test?
Claire
If the gas fire has a local point of isolation a drop test at the meter is not required. He could turn off the valve and soap test any new joints locally, this is acceptable.
Have you ever smelled gas or reported a smell of gas?
We have never had a smell of gas anywhere in the house...
But the drop test was literally dropping in front of our eyes instead of <4 in 2mins...
I thought this was just for servicing and that a tightness test should be carried out on all new installations, I certainly do and leave a print out of the test stapled to the installation paperwork.
There wasn't a hob burner left on or something like that? It sounds too bad to be a leak, more like an open burner, or a pilot light left on somewhere.
Yes you should have got a certificate from CORGI.
I have to agree with dave on this one, am sure that a new installation of an appliance MUST have a tightness test carried out
