About 12 years ago I installed a cooker with a gas hob connected to a propane bottle using parts obtained from a small retail outlet. I am installing a new kitchen and now need to dump the old cooker and install a permanent gas hob in a worktop. Unfortunately the place where I got the parts has closed down and I haven't been able to find anywhere else that stocks them.
I have tried the usual DIY places, several builders merchants, plumbers merchants, and LPG suppliers, but none stock the bits I need. My problem is I don't know exactly how to specify the items so I can order via the internet or by telephone. I especially need to know what dia copper tubing to get so I can install the pipe run through the wall before the kitchen floor units are installed. The old pipe seems to be about 9mm external diameter.
I also need a spigot end with compression fitting and a length of hose to connect the pipe run to the reducing valve which sits on the propane cylinder, and a compression fitting to fit a male 1/2 inch tapered connector on the hob.
Can anyone tell me what is the correct diameter of the tubing, and what the items are known as in the trade? Grateful for any advice.
