people who object to all the work required to get a cable to a new socket etc.
Can`t you just fix it on the wall and electric comes out? I wish.
why`s it getting hot , it`s only 12 volts?
My TV don`t work.
I don`t repair TVs.
It worked before you rewired my house , so there must be too much electric now.
Your wiring is faulty - everytime I use this electric fire it trips out.
No the RCD is seeing a fault.
It`s always worked before, no problem.
You`ve had it since the great war (Not Vera Lynn`s war the one before it).
You need a new fire.
No it`s your wiring.
I`ve always used silver paper in plugtops when a fuse blows, it`s always been safe.
These metal fittings have always worked OK without an earth, so why do they need one now?
I`ve always twisted wires together then taped them, no problem.
It`s only a 5 amp lighting circuit so it can`t be dangerous to touch.
I`ve had loads of shocks, stop being so soft.
The fuse kept blowing so I put a nail in, it`s OK now.
Of course this wire (1.5 T & E) is OK, it`s only running a washer and dryer, not a whole house.
Well a bloke down the pub says it`s OK and He should know, h`s a decorator. (0.5 3 core flex wired directly into kitchen socket to run striplights).
This (8.4KW) shower has ben running off this bedroom socket for 15 years, now I want a 10.8KW in I suddenly need a bigger cable .
I`ve done loads like this, never had a problem.
You should not have done any like this you pilchard!
