I am shopping for mains downlights mainly GU10's. I came across halogen GU10. Are these bulbs dimmable. Positive feedback will be appreciated. Thanks in advance.
Do expect to see reduced lamp life when the lamp is run at below full brilliance for sustained periods though... the halogen cycle relies on quite high temperatures to operate in the way the lamp designer intended
