Help needed albeit not "ban all sheds "
27 Dec 2010
Ayrshire
Help needed. I replaced my old timber garage with new and cut off the consumer unit to put back on after it was replaced. I just wanted to replace it to what was there before. A light and socket.
As stupid as it sounds I look at it now and think which one was the power supply, socket and light. I have an idea but better to confirm before putting back.
2 Jun 2005
Cumbria
Simplest way is follow the wires.
Otherwise you'll need a multimeter and to do some testing.
12 Apr 2012
Worcestershire
Focus on identifying the power supply. You could then disconnect the 5A one and carefully test the sockets with a low load (phone charger) to see if they are working, if they are then all is good, if they aren't then just swap them over.
3 Jan 2011
Cumberland
With the main switch off, and the lives and neutrals in the appropriate terminals, power it up.
If the light works you have got the two 2.5mm2 cables crossed
27 Dec 2010
Ayrshire
I should of explained the wires sticking out are cut about a metre below. I was going to replace the cable like for like. Single light and single socket are replaced now.
4 Jan 2004
Personally I'd replace the lot.
28 Jul 2006
Oxfordshire
You absolutely MUST have an RCD protecting that socket.
There is not one on that fuseboard, is there one on the power feed from the house to the garage? Or does the socket itself incorporate an RCD??
30 Jun 2009
Londonderry
What happened to old traditional method of testing with a voltage indicator, and then doing continuity tests, once you have determined the distribution cable?
27 Aug 2003
London
Help needed.
Indeed.
That, given a 5A fuse and a 15A one, you are unsure which would be for sockets and which for lights does show that you really ought to learn about things before you try fiddling with them.
2 Apr 2005
There's a thick red wire and a thin red one. Not sure where the problem lies. Thick = power = 15A.
28 Jan 2011
Buckinghamshire
...you really ought to learn about things before you try fiddling with them.
  • http://www.google.co.uk/search?q=electrical+circuits+101[/QUOTE]
    He certainly ought to know an awful lot by the time he's worked his way through that lot ... that Google search appears to result in ('about') 2,460,000 hits :)
    Maybe some slightly more specific (and slightly more restricted) guidance as regards reading/learning would be a little more helpful for him?
    Kind Regards, John
Similar threads
