STOP ITYou are confused. They are not transformers, but switch mode power supplies, see post 2.
It doesn't matter what they are, were or what they should be called in La La Land.
They are no longer connected and not part of the issue.
I fully agree. I did say "(unless it is ambiguous)". In this case Iggifer/PBoD and the OP had cleared that up before I posted.Never assume. You don't know.
That's not what you said.I fully agree. I did say "(unless it is ambiguous)". In this case Iggifer/PBoD and the OP had cleared that up before I posted.
FWIW, when I read questions from joe public on DIYNOT i assume: etc.
why do you ask?
In the context of this thread, which, again, you have contributed nothing of any value to the OP. The importance was to determine which lamps he had, GU5.3 or GU10.
If you have an issue with the MR16 term like you do with the term transformers, take your soapbox to the manufacturers and (mostly) resellers.
I thought it was called a transformer, they were halolite 20-60w/va model ha-se60. And can confirm completely removed. It is indeed the lamp closest to switch that is not flickering. About to check connections on each fitting.
MR16 = low voltage*
GU10 = Mains
Transformer = things that change Mains to low voltage*
I don't give it a moments thought that any of these things could or should be called anything else (unless it is ambiguous) . I also don't care if someone politely (while helping) points out that a MR16 doesn't necessarily mean low voltage*. But it does throw threads off track when all someone can do is be pedantic.
