Help with lintel size
1 Aug 2020
Hi Guys,
going to be building up to DPC for my project this week. There will be 2 bridges for water and electric supplies to run under the blocks... what size/rating lintel will i need (assumng i need 4 lintels also)?
Thanks.... 1200 x 100 x 65 should be fine then. The openings are only small enough for a 110mm pipe.... Or you recommend a shorter length?
Beams 400 long will do, as long as there is a 100 bearing each side. In fact, if the holes are only 110+mm wide, a full block will bridge it without the need for lintels.
Cheers ill just get the 1200 amd cut them in half to get 2 600s :)
