Hi Guys
I have two controllers in my home the downstairs which I have swapped for a Hot Water and Heating Hive and was a fairly easy swap as I just dropped the COM cable which was just a link from the live all up and running.
Downstairs wiring for reference..
Upstairs is a different kettle of fish, It just does two radiators in the bedroom the controller just turns a valve from the main hot water tank.
I took the controller off that has a battery backup and found just a Live 240v as I tested live with my multimeter going to the com port and the NO which I assume is the wire that triggers the valve.
I tested the grey (live) no voltage so assumed this to be my Neutral and the earth. Wired the hive with these assumptions, nothing, no power!
How should this be wired? into a hive?
