When it comes to outlets in the same room, then you look at diversity and dynamic pressure. In other words you won't be using all the appliances in the same room at the same time.
So if you want to avoid impact if say you flushed the toilet and then want to brush your teeth while the toilet fills then break up those supplies but ultimately are you liable to exceed the throughput of the 15mm pipe with more than one outlet open at the same time, that is decided by how good the dynamic pressure is.
Try this test, find a room with more than one outlet, run one as full open as you can then open the other one, is there a noticeable drop in supply at either outlet? Or get a wet test gauge and do a proper dynamic pressure test
