K
knowall
RF, gives you very good advice, all bases are covered
The dimmer is the key!
That sounds remarkably close to the "3 rows of 7" that the OP was thinking of for his 4m x 7.5m room!600mm from each wall and then every 1000mm - 1500mm there after seems to work well as a rule of thumb.
Yes.No, we are lighting it.
Very true. However, if one is talking about lamps with beam angles of 40°, 50° or even 60°, it is hardly correct,or reasonable, to describe or think of them as 'spots'.Spots are not really for general lighting. Yes bouncing light off the walls it can be done but if you want general light they are not the way to do it.
Kind Regards, John
