How to do lintels?
16 May 2005
Bath
I need to cut a single door into a breeze block wall. The breeze block wall is an infill into a taller archway that was obviously filled in a number of years ago.
General question on inserting lintels - How do you ensure that there is support throughout the process? I understand that you can for example use an acro prop to hold up the material above the door/window frame no longer supported by the material removed, but don't you have to cut a hole first so the prop has somewhere to stand? Alternatively I could envisage cutting a slot to slide the lintel in (with 150 mm bearing surfaces each side) before cutting away the bulk of the material but again there must be a period of time between cutting the slot and inserting the lintel when the material above is unsupported.
Any comments gratefully received
Robert
It's to link two parts of an old property that's been split in the past, so both sides will be for domestic type use although I haven't decided exactly what yet
Robert
hire a strongboy it fits to the top of an acrow and you only need to cut a slot out to take it.
Though for a 2' 6" doorway you should be able to get away with doing as you said cutting a slot for your lintel fit it in and then cut the rest of the opening.
Hi there,
I will be replacing a window with a patio door. The window is around 1.2m wide, the patio door around 2.4m wide.
Can someone plesae advise the safe procedure for removing/supporting etc and what I need in terms of the lintle (just a length of steel bar, thickness etc., or something specialist) ?
I can post pictures or add more info if required, just looking for the overall procedure.
Thank you.
