I need to cut a single door into a breeze block wall. The breeze block wall is an infill into a taller archway that was obviously filled in a number of years ago.
General question on inserting lintels - How do you ensure that there is support throughout the process? I understand that you can for example use an acro prop to hold up the material above the door/window frame no longer supported by the material removed, but don't you have to cut a hole first so the prop has somewhere to stand? Alternatively I could envisage cutting a slot to slide the lintel in (with 150 mm bearing surfaces each side) before cutting away the bulk of the material but again there must be a period of time between cutting the slot and inserting the lintel when the material above is unsupported.
Any comments gratefully received
Robert
Robert
