- Joined
- 11 Jan 2004
- Messages
- 46,396
- Reaction score
- 3,725
- Country
Does butyl have flexibility in the cold?
Outside temperatures in the UK. -20 max?
If it is going to be 'fixed' wiring, why are you concerned about its flexibility at low temperatures?...I had some 1.5 butyl and thought I'd use it (installed in a combination of wall-mounted high impact PVC conduit & clipped direct) to feed a Masterseal socket out on the drive. Thought it might be better suited than PVC to withstand the temperature fluctuations.
That obviously makes sense - but I still don't really understand why you are specifically interested in (i.e.asked about) the flexibility of butyl HR at low temp, when the application you're talking about presumably will afford the cable no opportunity to flex! I guess I'm missing something!Sure, it's fixed wiring, but if I've got something that could be better-suited to the low temps., I'd rather use that.
