WelshMan said:ChrisR, i live in Abercynon myself m8 . What pub did you stay at btw?
Btw Chrismac you must be nuts.....lead is brill !!!!!!!!!!!! . Any advice on the gola ?. While we got a few more left to cover my mind is already thinking on this, is there any practice tests out there. Or any other books/sites with good general info?
Its pretty hard to be honest but if you take time to revise EVERYTHING you should be ok. We all bought revision software from here http://www.learnatrade.co.uk/ which was actually a bit of a life saver plumbing level 2 revision is the best one to get. It gives you a wide selection of questions done in the same style as the gola test. You can also select different modules to revise depending on what you feel you are weak at.
No matter how prepared you are you also just have to keep your fingers crossed that you are lucky enough with the questions you get. The way some of them are worded makes them quite tricky, totally different to how they are worded in the other tests. As I am sure you already know, the gola test is online and no two people will get the same questions as the computer throws them out randomly from a choice of a few thousand or whatever. One of the guys in my class was unlucky enough to get mostly lead, which he never really revised on and as a result failed the test but dont worry. Like I said if you spend a bit of time revising everything then you should be ok mate.
