they don`t need one they never had bad rep
and one best heat ex out their
I'm sure there fantastic boilers but this was the point I was making, you can rave about a specific boiler but if the last bloke came along with a quote for a boiler with a 5 year warranty then even if they were say 100 quid more expensive then it's a more attractive offer. I mean if you made up the extra warranty by getting BG cover then it's still about 14quid a month for the lowest boiler cover.. That's £168 per annum x 3 just to get the same cover on an logic or viesman! Thing is the general public are not stupid and they know what's about, also if someone has had a logic fitted and they tell there friends guess what they will want.. No good me coming along saying grunfoss this and stainless steel that because they don't care unless you get someone with there head screwed on. Not many of them about..
Ps as I said above if yer engineer was any good he would have identified the wee red o ring catching in valve and pushed it through no leaving you without heat or hwhad an ideal logic+ fitted four weeks ago radiator burst closed valves called out engineer to sort it out, no problem rad changed came down stairs exact words " oh s**t forgot it was one of those has anyone operated the filling loop since fitted"
no was the reply
" ok will give it ago"
top and tale is he said all new logic and logic+ have faulty o rings in the water supply valve once used they pop out so cannot be used again unless you change the valves! been without hot water and heating now for 4 days as ideal are very busy and cannot get out till tuesday.
what a bag of crap!![]()
Remind me, how long was it before the Responses started dropping like flies?I wonder if any of the early posters on this thread would be interested in detracting their statements now that the Ideal Logic is a proven product...
