- Joined
- 19 Feb 2006
- Messages
- 31,925
- Reaction score
- 11,534
- Country
Dan do you fit WC on yours?
Love you Dan😍😍😍😍😍
Reading this whole thread, one, SilentDancer, says Intergas are crap because he thinks they are slightly less efficient. As they have few parts they obviously will be more reliable, cost less to service and less call out charges over its life so any slight increase in gas cost will be more than compensated by less maintenance charges. Then there is the reliability which equates to far less cold showers or no heat in the house. The other gripe is that hot water can be 70C at the tap in winter, unless a weather compensator sensor is fitted. The boiler has weather compensation as standard. Not to fit the sensor is madness when the boiler comes with it. They save gas. Back to efficiency, the Intergas with the weather compensator must be more efficient than an Ideal combi (supposed to be more efficient) without.
Dr Drivel has been flushed out.
If the Opentherm room thermostat is used as this again lowers the flow temperature along with the outside sensor, and the radiators are oversized it will not be 80C. The weather compensator can be set to 60C maximum. Most of the time a boiler is on part load, just like a car's engine. Most radiators are oversized and are oversized if double glazing and other insulation methods and draftproofing are used after the initial installation. Then there is incidental heat like the occupants, TV, lights, fridge, etc. Common sense really.Reading this whole thread, one, SilentDancer, says Intergas are crap because he thinks they are slightly less efficient. As they have few parts they obviously will be more reliable, cost less to service and less call out charges over its life so any slight increase in gas cost will be more than compensated by less maintenance charges. Then there is the reliability which equates to far less cold showers or no heat in the house. The other gripe is that hot water can be 70C at the tap in winter, unless a weather compensator sensor is fitted. The boiler has weather compensation as standard. Not to fit the sensor is madness when the boiler comes with it. They save gas. Back to efficiency, the Intergas with the weather compensator must be more efficient than an Ideal combi (supposed to be more efficient) without.
I don'tnt think you understand how weather comp works. At 0℃ outside flow temp will be at the maximum and therefore in the middle of winter you would get a 80℃+ slug out of the tap.
If the Opentherm room thermostat is used and the radiators are oversized it will not be 80C. The weather compensator can be set to 60C maximum. Most of the time a boiler is on part load, just like a car's engine. Most radiators are oversized and are oversized if double glazing and other insulation methods are used after the initial installation. Then there is incidental heat like the occupants, TV, lights, fridge, etc. Common sense really.Reading this whole thread, one, SilentDancer, says Intergas are crap because he thinks they are slightly less efficient. As they have few parts they obviously will be more reliable, cost less to service and less call out charges over its life so any slight increase in gas cost will be more than compensated by less maintenance charges. Then there is the reliability which equates to far less cold showers or no heat in the house. The other gripe is that hot water can be 70C at the tap in winter, unless a weather compensator sensor is fitted. The boiler has weather compensation as standard. Not to fit the sensor is madness when the boiler comes with it. They save gas. Back to efficiency, the Intergas with the weather compensator must be more efficient than an Ideal combi (supposed to be more efficient) without.
In 99% of cases they will be oversized. They always gave the 10% extra in sizing anyhow on top of what I stated. I would rather have a condensing boiler but cannot in my flat. But countless know-it-alls were saying I could not have one, and guess what? They were 100% wrong. But that is now a closed issues as I have a new Vokera SE keeping me warm right now.There's a big if there which is the radiators are oversized. In the majority of boiler replacement jobs are for 70/80s heating systems with radiators that are woefully small and designed to an 80℃ flow and 70℃ return.
Anyway I thought you were a big fan of standard efficiency boilers?
Unless sneak thief came in over night and changed it, it was there the last time I looked.I have a new Vokera SE keeping me warm right now.
No you haven't.
