Indesit WIDL126s washer dryer won't fill
27 Dec 2009
I set my washer dryer today in the normal way, and the light comes on as expected but the water won't fill the machine? Doesn't even sound like it's trying? Can anyone tell what the problem is and if it's an easy fix, such as a fuse, can someone tell me how to replace the fuse
I doubt it could be that already? I only have it about 5 months? It was shop soiled(had a few scratches on it) so I got it a bit cheaper and only got a 3 month warranty. :-(
if its shop soiled it should have 1 yers gtee i recon its a recon mc ,post up serial number ,that model is at least 3 years old
probably is reconditioned alright. But could it still be brushes even still? ANd is that a difficult job?
yes quite poss ,go to you tube and type in motor brushes washing mc, it shows how to do it.
just wanted to add, when I set the dial on to a drying setting and power the machine up, the diodes come on and again no power to get the machine moving? Does this still sound like brushes?
yes it does worn brushes you get no fill no spin just a light .
