Installing a neutral wire?
9 Jan 2014
Moray
Evening
I am needing to know if this is possible to install a neutral wire into a lighting circuit in the garage. Reason for this is, the Home Automation device requires a neutral wire.
Regards
Rich
If there is no neutral at the switch, there will be one at the light. However there may not be a permanent live at the light. What supply does this home automation need? Sure it can come off the lighting circuit?
Do you mean you require a neutral at a light switch?
If so, I assume there is a 2 core and earth cable at the switch?
If so, replace the 2 core and earth for a 3 core and earth and get the neutral from the light.
IF NOT, give us some more info.
Way to slow... ;)
The system runs off 230v the same as the lighting system.
Reason am asking is the normal modules i use melted just after installing into garage cause it uses tube lights and i only find out after that tube lights and these modules dont mix.
I will check the light and get back to you
Hi
I have attached picture of inside of light fitting. the bottom connection is labelled N and wire going into it.
Just take a feed from here correct?
Rich
Ah ok, presumably so you can switch the lights on remotely?
What wires do you currently have at the light fitting?
Do you also have 3 wires at the switch?
Does this resemble your lighting circuit layout?
