D
durhamplumber
Nothing to comprehend in your statement,it is too vagueI see reading comprehension is not your strong point.
Intergas flues are from the bottom with little heat floating out into the atmosphere. The case is insulated, so heat stays mainly inside the case. The Intergas has a clever preheat that does not preheat when there are lulls in DHW draw-off, say during the night. Also, it reduces the dead-leg draw-off of water reducing water bills and delivering DHW quicker. You could fit in a heavily insulated DHW secondary draw-off loop using a brass pump and pipe stat, but these tend to cost a lot to install and run.So what prevents the pre-heated heat exchanger from creating thermal convectional air flows through flue and dissipating ( some of ) the pre-heat to atmosphere ?
Many do. The two sensors, when the system is up to, or near setpoint temperatures will have the flow temperatures markedly reduced.
Eliminating, air leakages (draughts) and uprating insulation, triple glazing instead of double, increasing loft insulation, cavity wall insulation, insulated front door, etc, it the best way for any home, which will allow low flow temperatures from older radiators, giving more efficient condensing operation.
I was talking generally. The new Intergas boilers do work together I believe.
Grow up. They breed them on this forum.
To combat dead-leg draw-off problems, instant electric taps are becoming popular, with hot water following through from a combi or cylinder, cutting out the electric tap when through. BTW, a guy I know, after I alerted him to the, used these in his renovation to great success. Report to follow.
A fan flap was introduced in 2015 which solved this problem by stopping the convection circulation
Have the preheat set to the hour glass (it cleverly selects the time it preheats).genuine question, I have an Eco RF 30 (controlled with Opentherm) but I don't have the pre heat switched on, there's no one in the house between 9 and 17:00 with hot water usage mostly in the evening (washing up, showering etc.) and I don't have a water meter. Would I save gas switching the pre heat on?
But the burning question (pardon the pun) which is the most economical?Have the preheat set to the hour glass (it cleverly selects the time it preheats).
I mean between pre heat off and pre heat on.On the timer, the other one is having the pre-heat on constantly.
