Does it only do it on HW or does it do it with the CH on too ? I certainly do not think that a powerflush has anything to do with it.
It does it with the CH on as well, but it just takes a hell of a lot longer to get to that situation as I have to wait for the whole system to heat up.
The video above was when I turned the CH on, 2 hrs after I'd had the boiler on for hot water.
The problem is, now BG have diagnosed the blockage in the DHW flow/return and recommended a £700 powerflush, they won't visit us again till we've had that done. Which is why I'm trying to find out if what is happening IS normal if there's a blockage in the DHW flow/return, as I don't want to have to spend loads of money to then find out a new boiler is required (which would probably include a flush, or more likely be a combi rendering the blocked DHW pipes useless).
The only thing I can say with any certainty as regards a pattern is
IF the boiler hasn't been on for more than 2-3 hrs , it fires up fine
IF the boiler has been on in the last 2-3 hrs, even if it's cooled, it takes many many attempts to light.
