    Dismiss Notice
Is this cable suitable for exterior use
Discussion in 'Electrics UK' started by foxhole, 10 May 2021.
  1. foxhole
    foxhole
    14 Mar 2006
    17,853
    Thanks Received:
    2,048
    Kent
    Country:
  2. Sponsored Links
  3. securespark
    securespark
    11 Jan 2004
    36,926
    Thanks Received:
    1,272
    Country:
    SY is not intended for external use. It is intended for use indoors where additional protection is required.
  4. foxhole
    foxhole
    14 Mar 2006
    17,853
    Thanks Received:
    2,048
    Kent
    Country:
    Thanks .
  5. Risteard
    Risteard
    18 Jun 2010
    2,177
    Thanks Received:
    157
    Derry, Ireland
    Country:
    Ireland
    It's not intended for any use within a BS7671 installation. It is a non-compliant cable type. It is a flexible control cable.
  6. Donald Trump
    Donald Trump
    4 May 2021
    5
    Thanks Received:
    2
    Country:
    It is fine to use SY cable in a fixed installation. It can simply be noted as a departure from BS7671 on the EIC. As securespark has mentioned, it is not suitable for use outside without additional protection.
    • Thanks Thanks x 1
  7. Sponsored Links
  8. flameport
    flameport
    10 Mar 2007
    9,817
    Thanks Received:
    1,962
    Poole, Dorset
    Country:
    SY or any other cable could be used, provided the specifications of that cable have been obtained from the manufacturer, and it has been confirmed that it is suitable for use in the specific situation that it will be installed in, and other information such as current carrying capacity, temperature ratings and all the rest have also been considered and determined to be appropriate for the installation.
    Even then, it would only be applicable to that particular cable and that particular installation, and not cables of that type in general.
    It is not just a case of slinging any old cable in and then saying 'its a departure'.
    • Like Like x 2
  9. chivers67
    chivers67
    18 Nov 2008
    1,408
    Thanks Received:
    173
    Surrey
    Country:
    SY Cable is used quite a bit in Telecoms inside Mobile Phone Cabins and Transmission stations. Very good cable quite flexible and has a bit of mechanical protection. Used 6mm a great deal with green ferrules and proper SY Brass glands. You could run it in duct work outside as long as both ends are sealed to prevent any rodents gnawing on it?
  10. crystal ball
    crystal ball
    28 Apr 2004
    5,271
    Thanks Received:
    308
    Country:
    A factory I worked in had whole production areas wired in SY, because the MD liked the look of it opposed to SWA
  11. Nozzle
    Nozzle
    23 Dec 2012
    2,199
    Thanks Received:
    289
    Suffolk
    Country:
    I used some like that (albeit without the brading) for my UFH wiring centre/adaptable box. I needed more cores, and I didn't want to have loads of cables going from one floor to another (and having to terminate loads of earths and loads of neutrals together) when a couple of correctly rated, correctly labeled multiled cored cables like this were perfect.
    Nozzle
Loading...
Share This Page
