Chipping in as a heating installer (with experience of Intergas boilers) as opposed to an electrician, I understand the point the OP is trying to make but .....
1) I would hardly describe the Intergas as a bog standard boiler. In particular you have not explained how the Intergas boiler handles DHW and CH temperatures which is key to the solution.
2) The NTC data you provide is surely applicable only to the OTS which you have already stated you are not using. Is it relevant, 10k 12k or otherwise, so why confuse the issue?
Installing wiring in accordance with regulations and implementing a control system is one thing and clearly a qualified electrician is best placed to do that. Designing the system on the other hand is the responsibility of the heating installer who needs to demonstrate a good understanding of the materials specified. particularly the boiler in this case.
For the electrician to do his job properly he needs clear communication from the designer as to what is required as opposed to an open ended riddle such as that posed.
