kitchen units
14 Nov 2006
South Glamorgan
Hi Guys
heres what i wanna do, new worktop,fridge washing machine tumbler
(existing)need to conceal them behind new doors do i need to make the worktop wider to be able to put cabinet doors on or is there another way ? without buying all new ?
I am assuming you are getting integrated appliances because you will struggle to try to fit a door to a standard appliance. You would generally have a 600mm space for a washing machine, dryer etc... and you would not be able to fit a carcase in and then remove the inside base to slide an appliance in as it would probably be too tight due to the hinges.
If the above is irrelevant then an easy way of effectively widening the worktop is to fit an upstand against the walls first ( i.e a 4-5 inch rip of the front edge of a worktop ) and pushing your new worktops up to meet it which will give you either 28mm or 38mm more cover at the front depending on the thickness of your new tops. The down side to this is that it will cost you for a full length of worktop (or 2) just for you to rip the nose off it and the look it gives , while quite acceptable, is not everyone's cup of tea.
Easiest way is to use double postformed worktops which are around 660mm wide, this will give you the depth for new doors to fit infront of your existing free standing appliances. Either cut off the back bullnose or just butt against the wall and tiles will cover the curve.
Assuming you will be using 600mm standard doors then the hinge option is to use this though they don't always work with fridges.
Jason
