All too familar story!
Anyway, got some new Lighting to put up at home...the fittings are the shape of a 2D' fitting, but take a E27 filament lamp... Terminals are clearly designed for one cable only...and I need to loop from one fitting to the next, I can't stick connector blocks in them because they clearly arn't designed for this... a little heat proof sleeving is provided, so clearly anything like that is a very bad idea!
Only solution I can come up with is a round dry lining box in the ceiling, connections in there, flex out and fitting screwed over the top of it...I've got to patch up the ceiling anyway where R80 spots where previously, so cutting a hole isn't a big deal!
Anyone able to come up with anything better?
