26 Oct 2020
Hi all,
I have an 8m x 3m detached garage, its block and brick construction with open gables. It has a small loft within the pitch of the roof and at the far end is an external loft hatch - part decorative / part practical. The hatch has seen better days and i was up there at the weekend mucking about having a general survey and tidy. Whilst I was investigating the hatch i noticed that some of the blocks at the apex of the gable end either side of the hatch were loose, as in the mortar was no longer bonding them together. This isnt an obvious issue elsewhere, just around the hatch. I've attached a picture from the outside. Outer skin of bricks seems fine.
Can anyone please advise a practical way of bonding/fixing these back together? It's perhaps 8 blocks, 4 either side.
Cheers!
Razz.
Repointing either side or just the one side if that's all you can gain access to.
Do one side and when dry the other
Cheers Wayners. I can only access one side of the blocks so I guess all i can do is carefully rake out part way and repoint from the inside?! I'm hoping the ties are intact, not sure ive got an easy way of telling.
