    Dismiss Notice
Loud Shuddering noise from hot tap and possibly heating
Discussion in 'Plumbing and Central Heating' started by Sam Odell, 18 Oct 2019.
  1. Sam Odell
    Sam Odell
    18 Sep 2018
    26
    Thanks Received:
    Country:
    Hi All,
    recently, when I turn the bath hot tap on, just slightly, a very loud shuddering, like a pneumatic drill, can be heard from the pipes/floor/tap? When I turn the tap on fully, it stops. Is this water hammer? It doesn't happen all the time, just every so often. But it is so loud and sounds so violent I thought I'd ask about it.
    Also - last night, the central heating came on, and lo and behold - lying in bed, I heard a similar thrumming / thudding noise. I went to the bathroom, this time it was from somewhere else - perhaps the pipes/boiler downstairs?
    Any suggestions? Is this water hammer? A dodgy washer? A boiler issue? Water pressure? Do I need to fit one of those pressure valves?
    Many thanks
  2. Sponsored Links
  3. denso13
    denso13
    22 Jan 2007
    4,822
    Thanks Received:
    1,048
    Country:
    I'd guess the tap is the issue, probably washer or jumper. Take it apart and have a look if you can, it may be obvious when you do that.
  4. Sam Odell
    Sam Odell
    18 Sep 2018
    26
    Thanks Received:
    Country:
    But the heating...? Made a similar noise
  5. ianmcd
    ianmcd
    15 Aug 2010
    21,520
    Thanks Received:
    8,383
    Lanarkshire
    Country:
    What boiler do you have ?
  6. Sam Odell
    Sam Odell
    18 Sep 2018
    26
    Thanks Received:
    Country:
    combi boiler glowworm.
  7. ianmcd
    ianmcd
    15 Aug 2010
    21,520
    Thanks Received:
    8,383
    Lanarkshire
    Country:
    your boiler has a cold water isolation tap below the boiler , try closing that at night when you are going to bed, if you still get the noise then it is a boiler or heating fault and not a tap fault, or turn the boiler off and see if the tap still makes the noise
  8. Sam Odell
    Sam Odell
    18 Sep 2018
    26
    Thanks Received:
    Country:
    thanks, will do
  9. Sam Odell
    Sam Odell
    18 Sep 2018
    26
    Thanks Received:
    Country:
    It does it only when boiler is on. Hot tap only slightly on, just more than a trickle. Could it be something to do with steam? Water pressure or temperature? Or something more sinister? Thanks
  10. Sponsored Links
  11. Sam Odell
    Sam Odell
    18 Sep 2018
    26
    Thanks Received:
    Country:
    BTW there is no noise from boiler itself, just pipes near Bath. Not sure where the noise with the heating cane from though
  12. Harry Bloomfield
    Harry Bloomfield
    30 Dec 2018
    6,066
    Thanks Received:
    873
    Country:
    They could be two separate issues - one could be the tap itself needing some attention.
    The other could be as simple as a TRV which has been installed on the wrong end of a radiator. Do you have TRV's fitted (thermostatic valves on radiators), like an adjuster with numbers on it? If installed on the wrong end, when the room gets up to temperature they can begin vibrating. Turn it up or down a little and it will stop making the noise.
  13. Sam Odell
    Sam Odell
    18 Sep 2018
    26
    Thanks Received:
    Country:
    Thanks, but why would it start now, after years of being fine? And as per separate issue, bit of a coincidence that they both go at once? BTW the heating thing happened only once, the tap is constantly shuddering when hot open just slightly
    Thanks all
  14. Harry Bloomfield
    Harry Bloomfield
    30 Dec 2018
    6,066
    Thanks Received:
    873
    Country:
    All faults have to start at some time :)
    Fit a new washer to the tap and it will probably fix that problem.
    Your noisy heating has probably happened now, because you have only just (like us) begun to use your heating system in earnest.
    • Like Like x 1
  15. Sam Odell
    Sam Odell
    18 Sep 2018
    26
    Thanks Received:
    Country:
    If it's the washer, why does it only happen when the boiler is on?
  16. Harry Bloomfield
    Harry Bloomfield
    30 Dec 2018
    6,066
    Thanks Received:
    873
    Country:
    Have you any better ideas?
  17. CBW
    CBW
    26 Sep 2019
    6,573
    Thanks Received:
    1,728
    North
    Country:
    Do you have 1/4 turn taps? If one or more are failing, then this could be your noise. When you open the tap do any others start to run, drip, trickle?
Loading...
Share This Page
