Hi all, planning a new kitchen and wondering about narrowing the back door so as to fit larger units onto the adjacent wall. Current door is 2134 x 915mm, solid wood, framed in brick work. Its a big door for the size of the kitchen, would actually prefer it to be smaller so it swings out less also. I'd be adding 110mm of brick on one side roughly, worked out that a 813mm wide standard door would then be the nearest size i could fit. But my problem would be that 2032mm is the standard height for that. So question is what i am best to do with the 100mm ish delta in height that would be at the top of the door?
Order a custom 2134x813 door. Not sure this would look 'right'.
Put in a new lower lintel with the new brick work, brick up the gap to the existing lintel, plaster over.
Build the wood frame up(down) at the top then plaster board over 100mm of it. Not sure this is the done thing with an exterior door. would there be any issue to having a mega top frame piece size. Would have to cover over it some way on the outside too.
Any other suggestions welcome as this is not an area of expertise for me
Cheers
Cheers
