Neff U1421 oven blew - multiple times!
13 Oct 2004
My oven decided to go with a flash and soft bang last week when the wife went to switch it on. We switched the isolator off, turned the fuse box back on, then forgetting to turn the oven on/temp knob off, turned the isolator back on. The oven came on and heated up as normal, and then worked fine for a week. Switched on last night and bang again. Turned fuse on, turned oven on, works again. Turned on this morning, bang again. This time after resetting the lights are on but it's not heating up, so the element has gone i'd guess. Question is, what else should I look at replacing given the way in which it failed?
Thanks,
Spoodz
You should really have had it looked at the first time the rcd tripped. Problems of this type don't repair themselves. Regardless which element is defective (there are 3) the oven has to be removed in order to identify & replace it. If you are not comfortable troubleshooting electrical issues please call qualified assistance. The alternative can cost you dearly :shock:
