Ive replaced a switched wall light (two bulb) and rewired it the same but both lights are dim.
they have 25W bulbs in and are very dim and when I fit 40W bulbs the problem is worse, they are even dimmer (barely lit).
The light is fed from 1mm twin and earth.
The live goes straight into the small corded switch from the twin and earth.
A live comes out the other side of the corded switch to a connector strip.
Two lives from the opposite port feed each bulb.
The neutral from the twin and earth goes into a different port on the strip.
Two neutrals from the other side feed the bulbs.
A earth from the twin and earth goes into a different port on the strip.
The earth from the light casing meets that earth in the strip.
Pull the cord to turn the light on both bulbs are very dim.
Any help would be appreciated
