By the limited number of posts you’ve made that are not derogatory, you do seem to have an understanding of what your talking about, even if you won’t admit to being wrong on this occasion. I don’t understand why you’re so angry & as for slagging the OP because he questions if your post content is right!
That explains why you know s** all about lime mixes then?
By my own admission, I’m a self taught spread since around 2004 when my previous working life ended so can’t compete with your obvious experience. I’m not an expert as far as lime rendering goes either & only got into it as a result of a plastering problem I had around 3 years ago; but there have & still are other very experienced contributors on here whose advice I value & have sought in the past that would say otherwise.
Say alot about YOU when you think every post is about YOU.
I really don’t follow that. I’m sorry you feel aggrieved that I post about so many different things, that tends to happen when your multi trade. It’s why I get all the work I need across several trades; if you don’t diversify, you’ll die, especially at the moment.
Why wouldn't you fill between plasterboard unless you are just using tape? See what happened?
The idea is not to leave gaps, certainly not large ones as it involves filling but you always fill scrim tape as you go; but then you must know that.
It was another option, why would you gypframe then add thermaline reducing space when you have space to insulate between the gypframe?
"Gypframe, bpard and insulate" is what I said.
The OP needs an insulation barrier, he’s currently planning to do that using timber batten but could as easily use Gypframe, it’s merely a metal battening system; you can use it for any BG board system. My original suggestion was to use dot/dab which is perfectly OK with Thermaline as long as you use nailable plugs.
I have spent a while on this forum reading peaps posts.
peaps is an OK contributor along with others in plastering, I can’t remember having problems with him. I don’t post there much any longer as it’s generally well served with knowledgeable contributors &, as you know, I have other strings in my bow & rarely do just plastering anymore.
I will stick around atleast until we have finished here.
Sounds a bit sinister, what do you have planned
? Do you want to be his boyfriend?
Ere, your not
peaps alter ego are you! It won’t be the first time Plastering (or any of the forums for that matter) has been through disruptive periods.
Interesting that you post links to other DIY sources rather than follow the technical advice & recommendations of the people that actually make the stuff.
