Indeed, there's absolutely nothing wrong with 'belt and braces', and the very minor inconvenience of perhaps having top reset two RCDs after a fault is trivial.I have an external RCD socket on an RCD supply, the way I see it is if one fails at least there's a backup!.
If having a 30mA RCD feeding a 30 mA RCD is wrong, why does the BS7671 insist you do that with supplies to caravans and boats? I will admit for outdoor use the 10 mA RCD makes more sense, and today when more and more homes are already RCD protected one would expect to find most plug in RCD's to be 10 mA, however it seems hard to find them for sale.So you bought the wrong one then!
Presumably not - although the risk-averse amongst us might even consider that (given the apparent fairly high rate of in-service failure of RCDs).By the same reasoning is every socket in your house an RCD one?
I always assumed they did this because they knew full well that there was no way they could make every caravan park and marina (including those abroad) compliant, nor could they make every caravan and boat (including those visiting from abroad) compliant.why does the BS7671 insist you do that with supplies to caravans and boats?
