Outdoor light
8 Jun 2008
Staffordshire
I have a 500w PIR outdoor flood light which i want to connect to an FCU, what fuse should i use in the FCU for the floodlight.
And what type of cable should i use to connect the outdoor light to the FCU
Cheers
cheers, do we really need 500w- well we have quite a large garden so a large light should give of plenty light throughout the whole garden, i did not buy this light as it came free with with a garden table and chairs set.
Is 500w really too much, i will still connect up this light as it was free and we do need light in the garden
You can always opt for a 100W, 150W, 200W or 300W lamp instead of the usual 500....
ok cheers alot
even though its a 500w outdoor light, does that mean the actual bulb inside is 500w, and if so is it possible to buy a lower watt bulb although the light itself is a 500w
If you know what i mean by that, hard to explain im sorry :(
yes. 300w
but the problem is not so much the watts, more where you are going to put it.
in order to lighgt your garden you will put it up high, this then means you will light up the neighbours garden.
there is a neighbour abou 1/4 of a mile away ay the back, i can see hios light when it is on. doesnt bother me though, he is too far away, but if i look in his direction ican see it. its his neighbours i feel sorry for.
the best way to light a garden is to have multiple low wattage lights.
also the cheap lights tend to rot quickly
ok thanks, i will replace the 500w for a 300w, we have tall connifer trees in our garden so that should close off the light from our surrounding neighbours, would a 3 amp fuse be suitable in the fcu for the light with a 300w bulb
thanks
You can, as I suggested, go lower still (wattage-wise) if you wish.
