- Joined
- 25 Sep 2023
- Messages
- 2
- Reaction score
- 0
- Country
Hi all,
Wanted some advice on an outside bottle gully that I currently have. At the moment it has 3 appliance waste pipes going into the top of it and a redundant waste pipe on the side (which I want to use for a ACO driveway drain). The outlet feeds direct to the main drain (confirmed by lifting the manhole cover and testing) I am converting a summerhouse 4 metres away that I want to install a W/C and shower. My question is what options do I have?
On the inlet at the front of the gully can I connect the 4 inch pipe to that?
Can I put a branch in the outlet pipe and connect into that?
Does the gully need replacing altogther (if so how to connect the other waste pipes)
Hopefully you guys can help prevent a migraine coming on (yes I do suffer from them!)
Thank you in advance
