pipe puncture?
8 Nov 2007
Aberdeen
Recently, I put down several nails on the floor board of the en-suite in my upstairs bedroom, trying to cure the squeaking noise problem of the floorboard. Later on it occurred to me that there is a (PVC) waste pipe from the en-suite shower running beneath the floor (there may be a hole in the joist allowing the pipe through). I can tell one of the nails is pretty close to the pipe (from the noise that I knocked on the floor board I could tell there is a hole in the joist below), but not sure if it has hit the pipe or not. I poured water in the shower and there is no visible leak from downstairs ceiling. But I am still not 100% sure.
Is there any way to tell if the nail has hit the pipe without lifting the floorboard? Thanks a lot.
Tough one.
I hate using nails, I always use screws on floorboards. If there is a nail in the pipe it will be more or less keeping the water back (if its only gone through the top).
My advice is do nothing untill a damp patch appears underneath, then either rip up and repair (cut pipe and use straight connector if the pipes allow) or maybe take the nail out and insert of screw wrapped in PTFE.
Maybe practice the latter on a scrap piece of pipe first and see if it seals.
:D
dear all, thanks for your replies. so a hole on top of the pipe may be okay - normally the water will not overflow from the hole (it is waste pipe so not much pressure)? So for the moment I just leave it?
I'd leave it tbh. If it has gone through the nail will seal the hole anyway and even a small hole in the top of the pipe isn't gonna do much harm. If it shatters the pipe you'll see water pretty quick.
