Hi Guys,
I know there have been many similar questions about rear extensions, but I was hoping for some general guidance with regard to planning a self build or project managed single storey rear extension to a 3 bed end of terraced 1930's house in SW London.
We are thinking about knocking down our old lean to rear extension, which is only half the width of the house and very old and replacing it with a new rear extension. From research, it would appear that I can build up to 3m out without needing planning permission and assuming all other requirements are met regarding neighbours right to light etc. Having read a couple of case studies, it sounds like the boundary line with the neighbour can cause some issues, which I'll need to talk to them about.
I like to think that I am a competent DIYer, so to save as much cost as possible, plan to get as hands on as I can with regard to labour and will probably dig the foundations, demolish the old and generally get as stuck in as I can..
Am I right in thinking the following are the correct steps with regard to planning this project:
1. Get the architect in to draw up the plans and give general guidance.
2. Structural engineer for the steel on the existing back wall (not spanning the entire width of the house, but will be supported half way). Or can the architect do this?
3. Notify council so they can inspect for building regs
4. Build over sewer license? This is a tricky one as we have sewers running along the back porches of the houses. I have the plans for the existing half rear extension, which show that there was a manhole cover, which has been properly replaced with a dual sealed cover etc and built over. When we bought the house the HIP showed plans from Thames Water with no manhole on our property. Stops at the neighbours, so not sure if the original alterations indicate this is no longer an issue.
5. Start building?
Is any one aware of any good books or sites for guidance on a similar project?
Could anyone perhaps breakdown the approx costs of the above planning stages?
Thanks in advance
5. Start building?
Thanks in advance
