Is the back (front) door next to the sink unit?
That fresh plaster to the RHS of the gas meter - is that a cable chase? If so, is it in a safe zone?
Back door.
No it's from where I removed the old wall dividing the 2 rooms.
Ah - I hadn't made the connectionIt's the ring from my other thread that I extended! You suggested adding a leg to the new washing machine socket as opposed to a JB which I did. Now you see one leg in the top right, then another leg in the top left (going to the kettle socket). Connecting another leg between them completes the ring.
He's probably got those the wrong way round.The salesperson at John Lewis said the oven should be hard wired and the hob can be 3-pin plugged into the same 32A cooker circuit.
I doubt you'll get even that done for £200.Gas meter most probably be raised a bit
Yes but it looks like the CCU is directly above the hob or is everything to the left?Is this looking good?
Yes.Also the bottom right socket is technically a spur off a spur, correct?
No. Not if it is the only one.So it needs to be fused?
Why would you plaster before your complete the 1st fix electics ?
DS
Ah. Sorry, I misread that.Also the bottom right socket is technically a spur off a spur, correct?
If you don't hear anything from me it means there was an explosion!
That's pointless.Just extend the ring for the sake of 1m of cable.
I would ditch the electric hob as you have easy access to fit a supply pipe for a gas one. They are much easier to control and the fuel is way cheaper.
Gas is caveman compared to induction, and the sooner it goes away the better
